Command window loosing SERVEROUTPUT setting
Quantum
In my gLogin.sql I have: SET SERVEROUTPUT ON SIZE UNLIMITED
Initially (when a Command Window is opened and connected) the setting is respected, but when I disconnect and reconnect I have to manually execute the SET SERVEROUTPUT command for dbms_output to display its output.
Is there a way to preserve the setting?
Can you let me know how you disconnect and reconnect? Through commands in the Command Window, through buttons or menu items in the IDE, ...?
Test 1
I set my R13 to make no connection at start up:
1 In Define Connections window (under Imported Fixed Users in my case) make sure no Connection is checked: Uncheck Connect on Startup
2 Use Log off button in Session ribbon and select All
3 Close all windows (so that they won't reopen on next start up) and exit R13.
4 Start R13 and when prompted to make a connection click Cancel
5 Using the ribbon, select File-New-Command Window
6 Go to Session-Log on and select a connection
7 At the SQL prompt execute: EXEC dbms_output.put_line ('This is a test');
8 You get: PL/SQL procedure successfully completed
Test 2
1 Use Log off button in Session ribbon and select All
2 In Define Connections window select a Connection to connect on Startup
4 Start R13 (you won't get prompted to connect and no window is re-opened)
6 At the SQL prompt execute: EXEC dbms_output.put_line ('This is a test');
7 You get the correct result displayed: This is a test
8 Go to Session-Log off and select All
9 Go to Session-Log on and select the same connection
10 At the SQL prompt execute: EXEC dbms_output.put_line ('This is a test');
11 You get: PL/SQL procedure successfully completed
12 You have to manually enter: SET SERVEROUTPUT ON [UNLIMITED]
To answer your question:
About the items 8 and 9 in Test 2: you can log off and Log on either way, and the result is the same:
* Session-Log off
* On the status bar of the Command Window: Click on the Connection Indicator and from the drop-down menu select disconnect
* From the SQL prompt type: Disconnect
* After you are disconnected, use either way to connect: Session-Log on, Connection Indicator on the status bar, manually from the SQL prompt, or skip the connection and re-execute the dbms_output command right after the disconnect command.
Test 3
Item 1 to Item 7: Same as in Test 2
8 From the SQL prompt type: disconnect.
9 R13 responds: Not logged on
10 However, the Connection Indicator on the status bar still shows the connection as well as the colour assigned to this connection.
11 Type the SQL*Plus command: Show User, and you get the user that is connected
12 You don't need to reconnect, just execute the command: EXEC dbms_output.put_line ('This is a test') and the text is not displayed.
Hope this helps
Thank you
