Bernhard S
I have a SQL*Plus script which runs fine in SQL*Plus, containing a
. When I execute the same script in a PL/SQL Developer Command Window, I get
and the query that is supposed to get spooled won't generate any output in the spoolfile! I think PL/SQL Developer should be able to at least tolerate all the possible SQL*Plus commands and not fail queries if one of those is used in a script.
Otherwise you're forced to write different scripts for PL/SQL Developer and SQL*Plus, which really sucks!
SQL:
set trimspool on
Cannot SET TRIMSPOOL
