Command Window Echo preference
In the 5.1.4 release, one of the fixes was:
"Command Window fixes: When executing a command file from the clipboard, Echo would always be on."
Some of us Liked it that way! Would you consider adding a user setting for the Command Window to store the preferred state of the "Echo"?
Thanx,
HMD
If you edit the login.sql file in the PL/SQL Developer installation directory, and add the line SET ECHO ON, then this will be the default.
