column selection (ALT+left-mouse-key)
(using 11.0.0.1762)
after marking a block in column selection mode I copy the block with Ctrl+C. Moving the cursor to a new position and pressing Ctrl-V the block is inserted as if I marked it in ordinary mode - i.e. destroys the column structure and insert newline for each line in the block. so it is not possible any more to switch columns over several lines. (command window, sql window as well as program window)
with 10.0.5.1710 this was possible - is this a bug or is it my fault.
thanks
raimund
