Column of the Explain Plan window
DLGL
If I execute the explain Plan window and in my preferences I have chosen to show a lot of columns I am unable to see columns that does not fit in the window there is no scroll bar to see hidden column.
Is there a way to see all the columns?
I have done a copy/paste in Excel but there is no header copied.
Thanks !
*IF* this is the same as I have reported before, you *might* be able to force the horizontal scroll bar to appear by resizing the last column to a very small size. With the cursor on the column separator click and drag it towards the right side of the grid. When you get to about to the point where the column will 'disappear' the scroll bar *might* appear. It works in the other places that I have seen this.
Scott Mattes
Tried what you said but it does not work. I did more testing and I was able to enable the horizontal scroll bar only for the first column of the explain plan window (column description). To do so I had to resize the explain plan window small enough to hide part of the "description" column. The scroll bar was only moving for the "description" column !?!
Thanks for your help,
Serge Fortin - D.L.G.L. Ltd.
Unfortunately the scrollbar does not allow you to scroll through the columns. This will be fixed in the next release.
