Pls. i use Express DBEditors 4 with DOA,
and when i enter in qbe mode dbeditors don't
change background colour.
But thing works just fine when I use standard
dbeditors.
Does someone have some similar expiriences and tips how to resolve this problem.
Problem is when you have data module with data sources, and these data sources are used in many forms. This solution is hard to implement.
Is there a way to implement AfterQBE and Before QBE in form where is needed QBE,
and leave datasources in central data module?
You will have to check all controls of the application, and set its color if it is connected to this dataset:
for i := 0 to ApplicationComponentCount - 1 do
if ApplicationComponents(i) is TSomeControl and
TSomeControl(ApplicationComponents(i)).DataSource.DataSet = ThisDataSet then
// and so on
