Code Contents bug?
Marcel Hoefs
Just recently we are experiencing a bug in the procedure editor, more specifically the code contents window. After some research we found that it is probably a parsing bug related to case expressions.
The following piece of code leads to an empty code contents window:
FOR r_var IN c_var
(b_var => CASE t_var
            WHEN 'value1'
            THEN 'value2'
            ELSE 'value3'
          END
LOOP
We are using PL/SQL developer 6.06.947 but it also occurs in trial version 7.1.0.1337
Does anybody else know of this problem and in which version of PL/SQL developer this will be fixed?
Thanks, Marcel.
Originally posted by Marco Kalter:
We'll fix it.
Marco,
Today I tried PL/SQL Developer version 7.1.3.1380 and in this version I still experience the same problem. As we have a lot of code where this problem occurs the usability of PL/SQL Developer is significantly compromised. In a couple of months we have to decide if we are going to upgrade our PL/SQL Developer license. A key factor for this decision is the usability of the various IDEs with our code base, so we are very anxious for a solution.
Can you tell me in which version this problem will be fixed?
I get this error too.
It is the combination of a cursor for loop and a case statement used as parameter that causes the error.
We used to get this error too. It also occurs in TOAD.
A good alternative is SQL-Developer (free) from Oracle. Seems more robust for the more complex code.
SQL-Developer. That's gotta sting, eh? I hadn't realized SQL-Developer had a code contents window yet.
That's OK - You'll get them next week!
Have a good weekend,
Mike
TOAD 9 now supports these offending CASE expressions.
When is this fixed in plsql-developer? I prefer plsqldeveloper to TOAD, but when this problem remains I cannot maintain my most important packages.
