Claus Pedersen
I have a package myPackage with two overloads of a method, defined like this:
When I type
the code completion automatically opens, and I can switch to the preferred overload by clicking the small left/right arrow keys at the bottom of the popup. This is by design.
But if I envoke code completion manually (F6) with the cursor after the opening parenthesis, the parameter onlyParameter is always filled in automatically. I have to delete the parenthesis, type it again, and wait for the automatic code completion to pop up, before I can select the parameters from the second overload.
Please fix this.
PROCEDURE tester (onlyParameter NUMBER);
PROCEDURE tester (firstParameter NUMBER,
secondParameter NUMBER);
When I type
myPackage.tester (
Please fix this.
