Code Assistant, view record variable
Maxnet
PlSql Developer does not popup values via Code Assistant in next example:
1 CREATE OR REPLACE PROCEDURE MTest IS
  2    TYPE rec_type IS RECORD(
  3      n1 NUMBER,
  4      n2 NUMBER);
  5    TYPE tab_type IS TABLE OF rec_type;
  6
  7    l_rec rec_type;
  8    l_tab tab_type;
  9  BEGIN
 10    SELECT 1,1 BULK COLLECT INTO   l_tab  FROM   dual;
 11    SELECT 1,1              INTO   l_rec  FROM   dual;
 12    dbms_output.put_line(l_rec.n1);
 13    dbms_output.put_line(l_tab(1).n1);
 14  END;
The Code Assistant pops up for l_rec. (line 12), but not for l_tab(1). (line 13)
PL/SQL Developer Version 8.0.3.1510
This is indeed beyond the current capabilities of the Code Assistant. I have added this to the list of enhancement requests though.
