Code Assistant sometimes not automatic
Sometimes, the Code Assistant does not automatically work and sometimes it does. One theory I have is that it has to do with large .sql files--I often use a file that has 500+ lines or 20,000+ bytes. I can type the exact same statement and sometimes the code assistant works automatically and sometimes it does not. Is this a "known issue"? (I'm using version 7.0.2.1076)
thanks,
pat holmes
PL/SQL Developer
Version 7.0.2.1076 (MBCS)
01.32373 - 1 user license
Physical memory : 916,912 kB (168,840 available)
Paging file : 2,223,532 kB (1,552,848 available)
Virtual memory : 2,097,024 kB (1,996,592 available)
I'm not aware of any problem. If you have a reproducible case, please send me the package source and we'll investigate it.
Unfortunately, I think the problem is intermittent and not easily reproducible. I'll see what I can do.
FYI: I did try the free SQL developer tool from Oracle, but your tool is dramatically superior. Your tool is still a better value. Oracle would have to pay me a small fortune to get me to switch!
thanks,
pat
