Code assistant is slow
pavel_j
I'm using using 8.0.4.1514 on Win7/64bit
on my old PC it was working without problem
after moving to new PC with more memory/cpu/etc, with the same OS (win7/64bit) I began to have a problem with code assistant. OS was reinstalled, config for PLSQLdev was taken from the old PC.
writting this SQL:
select * from buffer_e e where e.
after "." it takes about 5 seconds to show columns. It's unusable. The similar times for the others table (with less columns).
With trial version 9.0.6 it's OK.
I have logs from Process Monitor (sysinternals) from both versions 8.0.4 vs 9.0.6
I have also logs from PLSQL developer with parameter DebugSQL from both versions, but comparing I couldn't find any problem.
Homes
odac11 (C:\Program Files (x86)\Oracle\Oracle Instant Client\)
OraClient11g_home1 (c:\oracle\client32\product\11.2.0\client_1)
DLLs
C:\Program Files (x86)\Oracle\Oracle Instant Client\oci.dll
TNS File
C:\Program Files (x86)\Oracle\Oracle Instant Client\Network\Admin\tnsnames.ora
Using
Home: odac11
DLL: C:\Program Files (x86)\Oracle\Oracle Instant Client\oci.dll
OCI: version 11.1
Oracle Database 10g Release 10.2.0.5.0
I was also trying to change odac11 to OraClient11g_home1 but it's the same.
I don't know what is wrong?
Pavel Jurzykowski
