I am noticing PL/SQL Developer hangs when rendering the Code Assistant dropdown on the SYS schema. Is there a way to selectively disable or filter the results for this schema only? Or is it possible there's another setting implicated in the hang? I couldn't find anything in the manual or in the forums mentioning this but if you could point me in the right direction it would be much appreciated. Thanks!
My Code Assistant Settings Page Options:
Automatically activated: true
Delay: 500ms
Filter method for subitems: Contains
Coding Style: Lowercase
Describe Users: all checked
Describe Context: true
Minimum characters: 3
Include columns from DML statements: false
Describe standard functions: true
Show variable and type declarations in a popup: true
Align parameter values when selecting multiple: true
Maximum items on one line when selecting multiple items: 2
Delay: 500ms
