Code Assistant and current_schema?
swalker
Greetings, I'm using PL/SQL Developer 7.1.4.1390.
I noticed that placing this:
ALTER SESSION SET current_schema = SCHEMA;
into my AfterConnect.sql does not work as expected.
Meaning, I can perform selects, etc. without issue, but the Code Assistant still refuses to perform auto-completion unless I specify the schema name first.
I had found a few posts stating that this would be in the final release of 7.1.0, but perhaps there was a miscommunication.
looks like this is still not working in the current version 8.0.4.1514 either.
An example:
I connect as system in PSD and have an SQL window open.
When I enter there:
SQL:
select * from scott.emp e
 where e.
the code assistant gets activated and I get suggestions with all the columns of table emp.
Now I do an
SQL:
alter session set current_schema=SCOTT;
in the same SQL Window. I'd expect that now I get the same code assistant suggestions already without prefixing the table name in the query:
SQL:
select * from emp e
 where e.
However that doesn't trigger the code assistant. It will still only show up when prefixing the table as I did before.
There are indeed posts claiming that it should be fixed in a version 7 already. Was this ever fixed or just always postponed to later versions? When will this get fixed for real?
