code assistant and a scrolling window
hbar
Ok, let's see if I can explain this one...
I've got an SQL window with a query where one particular condition is an expresstion that is wider than the display, causing the display to scroll as I type. However, if the window tries to scroll while code assistant is up, it removes the code assistant window, leaving me hopelessly in the dark. :rolleyes:
Anyhoo, can you make the code assistant stay up whilst the window is scrolling? Let me know if you need a more clear description of what I'm describing.
