CLOBs using C++ Builder
Stephen
I see lots of examples using Delphi but non for C++ Builder with the temporary LOB (CreateTemporary) calls.
I don't even know if that's what I need to do....
I have an Oracle function inside a package:
SQL:
function my_func(pJSON in clob) returning clob is
  cRetval clob := empty_clob();
  cRetval := 'some long text value in JSON format';
  return cRetval;
I use the Package Wizard to create components for each of my packages.
I want to call this function from C++ Builder, passing in a CLOB and receiving a CLOB in return.
Code that was working (but not with 11.3):
TLOBLocator *inp = new TLOBLocator(OraSession, otCLOB, true);
inp->AsString = "some JSON input string";
TLOBLocator *outp = MyPackage->MyFunc(inp);      // <<- crash here
ShowMessage(outp->AsString);
delete outp;
delete inp;
Any help (with examples) would be greatly appreciated!
SQL:
function TMyPackage.my_func(Pjson: TLOBLocator): TLOBLocator;
  Result := TLOBLocator.Create(Session, otCLOB);
  ThreadAcquire;
  try
    GetQuery;
    OCPQuery.DeclareVariable('function_result', otCLOB);
    OCPQuery.SetComplexVariable('function_result', Result);
    OCPQuery.DeclareVariable('PJSON', otCLOB);
    OCPQuery.SetComplexVariable('PJSON', Pjson);
    OCPQuery.SQL.Add('begin');
    OCPQuery.SQL.Add('  :function_result := "MYPACKAGE_PAKG"."MY_FUNC"(PJSON => :PJSON);');
    OCPQuery.SQL.Add('end;');
    OCPQuery.Execute;
  except
    ThreadRelease;
    Result.Free;
    raise;
  ThreadRelease;
I can replicated this function by creating the query and declaring the parameters without a problem. The issue is when I try to call it from within the component that is created by the wizard.
Interestingly enough, if I modify the call (from the initial post) where I'm not even looking at the return value such as:
I still receiver the error ORA-03120: two-task conversion routine: integer overflow. When I look up this error, I get the response that it is usually generated from the calling program. I can run the stored procedure all day long using the CLOB I'm passing in to the function and I've verified that it indeed has a value when I'm passing it in.
Also, it works just fine when I replicate the code above where I create the query, the 2 TLOBLocators and declare and set everything.
Can you change
to
Result := TLOBLocator.CreateTemporary(Session, otCLOB, True);
and try again?
