CLOB through view
dragot
Sorry for my bad english.
I have some trouble. Situation:
I have two schemas A and B. In schema A I have table T and in this table is clob field. Schema B doesn't have any right to the A.T . Then I create view V on table T and grant all privileges on view V to schema B. And then when I try to change the entry in the clob field I get message: TABLE OR VIEW DOESN'T EXIST (all other data type fields can be changed, e.g. varchar, etc.).
When I try the same using SQL statement using e.g. SQLWorkSheet and not the OracleDataSet component, it works fine.
When I grant all priveleges to the table T on schema B (all other things staying unchanged) it works too (but it is not convenient for my situation).
Can anyone please give me the solution.
How do you perform this update in SQLWorksheet? Probably by supplying a string literal, which is limited to 4KB (or 32KB, I'm not sure).
The TOracleDataSet first creates an empty CLOB, and subsequently writes the data through a TLOBLocator. This requires privileges on the underlying table, where the CLOB column is defined. These extra privileges are the solution.
But I need the user of schema B not to see all rows and also to have privileges just to some of them and not to the whole table T. That's why I have to use view (or do you see any other possibility?).
I still do not understand why it works when I use the SQL statement and using OracleDataSet component I get only Error message.
If you are using a string literal in SQL*Plus, then is simply passes through the view and is converted to a CLOB on the server. The same statement will work in a TOracleQuery and TOracleDataSet. The size is limited though, so it's not useful for a general solution.
The next version of Direct Oracle Access will support temporary LOB's, which are new in Net8 8.1. Temporory LOB's should remove this restriction.
