CLOB display hangs
peledc
On PL/SQL Developer, version 7.1.4.1390
When I open a SQL window, select data and click on a CLOB window to view it's contents with the "large data view" The application hangs for a long time. I waited more than 60 minutes with no progress. This happens on other Oracle DB and on other desktop pc in my place.
I have run the application with DEBUGSQL and bellow is the output:
Alon Peled
PL/SQL Developer
Version 7.1.4.1390
Windows 2000 Professional 5.0 Build 2195 (Service Pack 4)
Physical memory : 1,023,220 kB (577,148 available)
Paging file : 2,462,088 kB (2,055,768 available)
Virtual memory : 2,097,024 kB (2,029,628 available)
Parameters
debugsql
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
12/02/2008 14:31:00 Application started
12/02/2008 14:31:00 InitPreferences
12/02/2008 14:31:00 Load C:\Program Files\PLSQL Developer\Preferences\Default = 0
12/02/2008 14:31:00 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
12/02/2008 14:31:00 PreferenceSet.Load OK
12/02/2008 14:31:00 Determine LocalPrefPath
12/02/2008 14:31:00 [1]: C:\Program Files\PLSQL Developer\Preferences
12/02/2008 14:31:00 LocalPrefPath: C:\Program Files\PLSQL Developer\Preferences\alon_pe
12/02/2008 14:31:00 Load C:\Program Files\PLSQL Developer\Preferences\alon_pe = 0
12/02/2008 14:31:00 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\alon_pe\default.ini
12/02/2008 14:31:00 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\alon_pe\user.prefs
12/02/2008 14:31:00 InitPreferences end
12/02/2008 14:31:00 SortPreferenceSets
12/02/2008 14:31:00 - Default alon_pe
12/02/2008 14:31:00 - System Default
12/02/2008 14:31:00 pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
12/02/2008 14:31:00 ReadString OK
12/02/2008 14:31:00 pfReadRegistry: "C:\Program Files\PLSQL Developer\plsqldev.exe" "%1"
12/02/2008 14:31:00 LoadPreferences
12/02/2008 14:31:00 LoadPreferences searching for default
12/02/2008 14:31:00 C:\Program Files\PLSQL Developer\Preferences\alon_pe\default.ini
12/02/2008 14:31:00 LoadPreferences NewPref := nil
12/02/2008 14:31:00 LoadPreferences Reading preferences
12/02/2008 14:31:00 LoadPreferences ReadPosition
12/02/2008 14:31:00 LoadPreferences ToolsBrowserItemClick(nil)
12/02/2008 14:31:00 LoadPreferences CreateBrowserFilters...
12/02/2008 14:31:00 LoadPreferences Files
12/02/2008 14:31:00 LoadPreferences Logon
12/02/2008 14:31:00 LoadPreferences Buttons
12/02/2008 14:31:00 LoadPreferences Printer
12/02/2008 14:31:00 LoadPreferences BrowserFolders
12/02/2008 14:31:00 LoadPreferences end
12/02/2008 14:31:00 MacroLibFilename: C:\Program Files\PLSQL Developer\Macro\alon_pe.lib
12/02/2008 14:31:00 FormCreate Logon.Execute
12/02/2008 14:31:02 TOracleSession PLSQLDevForm.Session Start Session.LogOn as a2c@opensys_tst
12/02/2008 14:31:04 TOracleQuery BytesPerCharacterQuery Start Query.Execute
12/02/2008 14:31:04 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.047
Duration = 0
12/02/2008 14:31:04 TOracleQuery Query Start Query.Execute
12/02/2008 14:31:04 TOracleQuery Query End (1 record processed)
Duration = 0
12/02/2008 14:31:04 TOracleSession PLSQLDevForm.Session End
Duration = 1.406
12/02/2008 14:31:04 LogonHistorySave start
12/02/2008 14:31:04 ChangeUserPref LogonHistory,
12/02/2008 14:31:04 ChangeUserPref DSA,
12/02/2008 14:31:04 ChangeUserPref end
12/02/2008 14:31:04 ChangeUserPref ColumnAssociations,
12/02/2008 14:31:04 ChangeUserPref ImportAssociations,
12/02/2008 14:31:04 ChangeUserPref BrowserFilters,
12/02/2008 14:31:04 ChangeUserPref BrowserFolders,
12/02/2008 14:31:04 ChangeUserPref SessionQueries,
12/02/2008 14:31:04 ChangeUserPref ExternalTools,
12/02/2008 14:31:04 ChangeUserPref Documents,
12/02/2008 14:31:04 ChangeUserPref Reports,
12/02/2008 14:31:04 LogonHistorySave end
12/02/2008 14:31:04 FormCreate Session.Connected
12/02/2008 14:31:04 FormCreate Logon.Executed -1
12/02/2008 14:31:04 FormCreate TDBNames.Make
12/02/2008 14:31:04 FormCreate SessionChanged
SQL = select * from v$version
12/02/2008 14:31:04 TOracleQuery Query End (5 records processed)
Duration = 0.016
12/02/2008 14:31:04 SessionChanged SetDBAViews
12/02/2008 14:31:04 TOracleQuery $0310FDC0 Start Query.Execute
12/02/2008 14:31:04 TOracleQuery $0310FDC0 End (0 records processed)
Duration = 0
Duration = 0.015
12/02/2008 14:31:04 SessionChanged Authorizations.Load
12/02/2008 14:31:04 TOracleQuery $0310FC60 Start Query.Execute
sys.plsqldev_authorization
12/02/2008 14:31:04 TOracleQuery $0310FC60 End
Duration = 0.016
12/02/2008 14:31:04 SessionChanged EnableAuthorizedMenus
12/02/2008 14:31:04 TOracleSession $019AF1D0 Start Session.LogOn as a2c@opensys_tst
Duration = 0
12/02/2008 14:31:04 TOracleSession $019AF1D0 End
Duration = 0.156
12/02/2008 14:31:04 SetSessionAction starts: Main session
12/02/2008 14:31:04 TOracleQuery $0310FF20 Start Query.Execute
from sys.user_objects o
SQL = select null from dual
12/02/2008 14:31:04 TOracleQuery $0310FDC0 End (1 record processed)
Duration = 0
12/02/2008 14:31:04 TOracleQuery $0310FF20 End (100 records processed)
Duration = 0
:ACTION = Main session
12/02/2008 14:31:04 TOracleQuery $0310FF20 Start Query.Next for up to 100 records
Duration = 0
Duration = 0.016
Duration = 0
12/02/2008 14:31:04 SetSessionAction ends
12/02/2008 14:31:04 ExecuteConnectScript starts
12/02/2008 14:31:04 ExecuteConnectScript ends
12/02/2008 14:31:04 TOracleQuery $0310FF20 End (37 records processed)
Duration = 0
12/02/2008 14:31:04 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
from all_synonyms s,
sys.all_objects o
and o.owner = s.table_owner
12/02/2008 14:31:04 TOracleQuery PLSQLDevForm.DynamicQuery End (1 record processed)
Duration = 0
12/02/2008 14:31:04 SessionChanged LoadRecentObjects
12/02/2008 14:31:04 SessionChanged Notify children
12/02/2008 14:31:04 SessionChanged Logoff secondary sessions
12/02/2008 14:31:04 SessionChanged SessionMode = smMulti
12/02/2008 14:31:04 SessionChanged EnableChildFunctions
OracleHomeKey: SOFTWARE\ORACLE\KEY_OraClient10g_home
OracleHomeDir: O:\ORACLE\ORA10
Found: oci.dll
Using: O:\ORACLE\ORA10\bin\oci.dll
SQL = select value from sys.nls_database_parameters where parameter = 'NLS_CHARACTERSET'
Duration = 0
12/02/2008 14:31:04 SortPreferenceSets
12/02/2008 14:31:04 - Default alon_pe
12/02/2008 14:31:04 - System Default
12/02/2008 14:31:04 TOracleQuery $0310FB00 Start Query.Execute
12/02/2008 14:31:04 TOracleQuery $0310FB00 End (0 records processed)
Duration = 0
Duration = 0
12/02/2008 14:31:04 WMUpdatePopups starts
12/02/2008 14:31:04 GetCrashList: 1376352.cfg
Duration = 0.297
Duration = 0.016
12/02/2008 14:31:05 TOracleQuery $0310FF20 End (100 records processed)
Duration = 0.078
12/02/2008 14:31:05 TOracleQuery $0310FF20 Start Query.Next for up to 100 records
Duration = 0.031
Duration = 0.062
Duration = 0.063
Duration = 0.015
Duration = 0.016
Duration = 0.047
12/02/2008 14:31:05 TOracleQuery $0310FF20 End (25 records processed)
Duration = 0.156
12/02/2008 14:31:05 TOracleSession $019AF1D0 Start Session.LogOff
12/02/2008 14:31:05 TOracleSession $019AF1D0 End
Duration = 0
12/02/2008 14:31:06 Create TSQLForm Start
12/02/2008 14:31:06 Create TSQLForm Inherited
12/02/2008 14:31:06 TSQLForm.FormCreate Start
12/02/2008 14:31:06 SQLForm
12/02/2008 14:31:07 TSQLForm.FormCreate Finished
12/02/2008 14:31:07 Create TSQLForm SetupMainFont
12/02/2008 14:31:07 Create TSQLForm Activate
12/02/2008 14:31:07 Create TSQLForm Activate done
12/02/2008 14:31:07 Create TSQLForm UpdateWindowList
12/02/2008 14:31:07 Create TSQLForm Positioning
12/02/2008 14:31:07 Create TSQLForm Finished
12/02/2008 14:31:07 FileAge: C:\DOCUME~1\alon_pe\LOCALS~1\Temp\PLS-Recovery\1376352.001 = 14:24:22
12/02/2008 14:31:07 SQLForm
12/02/2008 14:31:07 SQLForm Recovery file loaded
12/02/2008 14:31:07 NavigationBookmarks.EnableButtons(Rebuild)
12/02/2008 14:31:07 NavigationBookmarks: Backward=0, Forward=0
12/02/2008 14:31:07 WMUpdatePopups ends
12/02/2008 14:31:09 SQLForm Initializing...
12/02/2008 14:31:09 SetConnected starts
12/02/2008 14:31:09 SetConnected: Connect starts
12/02/2008 14:31:09 TOracleSession $019B2650 Start Session.LogOn as a2c@opensys_tst
12/02/2008 14:31:09 TOracleQuery Query Start Query.Execute
12/02/2008 14:31:09 TOracleQuery Query End (1 record processed)
Duration = 0
12/02/2008 14:31:09 TOracleSession $019B2650 End
Duration = 0.125
12/02/2008 14:31:09 SetConnected: (Dis)connect ends
12/02/2008 14:31:09 SetSessionAction starts: SQL Window - select A.Request_Id,A.Id,A.Timesmtp,EXTRACT((A.message),'/Message/OrchestrationName/text()').get ...
12/02/2008 14:31:09 TOracleQuery $0310F580 Start Query.Execute
12/02/2008 14:31:09 TOracleQuery $0310F580 End (1 record processed)
Duration = 0
12/02/2008 14:31:09 TOracleQuery BytesPerCharacterQuery Start Query.Execute
12/02/2008 14:31:09 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0
Duration = 0
:ACTION = SQL Window - select A.Request_Id,A.Id,A.Timesmtp,EXTRACT((A.message),'/Message/OrchestrationName/text()').get ...
Duration = 0
12/02/2008 14:31:09 SetSessionAction ends
12/02/2008 14:31:09 ExecuteConnectScript starts
12/02/2008 14:31:09 ExecuteConnectScript ends
Duration = 0.016
12/02/2008 14:31:09 EnableOutput starts
12/02/2008 14:31:09 TOracleQuery PLSQLDevForm.EnableOutputQuery Start Query.Execute
SQL = begin
if :enable = 0 then
sys.dbms_output.disable;
else
sys.dbms_output.enable(:size);
end if;
:ENABLE = 1
:SIZE = 10000
12/02/2008 14:31:09 TOracleQuery PLSQLDevForm.EnableOutputQuery End
Duration = 0
12/02/2008 14:31:09 EnableOutput done
12/02/2008 14:31:09 InitStatistics starts
12/02/2008 14:31:09 TStatistics.Init starts
12/02/2008 14:31:09 InitStatNames starts
12/02/2008 14:31:09 select name from v$statname order by statistic#
12/02/2008 14:31:09 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
SQL = select name from v$statname order by statistic#
12/02/2008 14:31:09 TOracleQuery PLSQLDevForm.DynamicQuery End
Duration = 0
12/02/2008 14:31:09 TStatistics.Init ends
12/02/2008 14:31:09 InitStatistics ends
12/02/2008 14:31:09 NavigationBookmarks.EnableButtons(Rebuild)
12/02/2008 14:31:09 NavigationBookmarks: Backward=0, Forward=0
12/02/2008 14:31:09 SQLForm Executing...
12/02/2008 14:31:09 TSQLThread SQLThread.Execute
:ID = Null
Duration = 0
12/02/2008 14:31:09 TOracleQuery $0310F6E0 Start Query.Execute
SQL = select A.Request_Id,A.Id,A.Timesmtp,EXTRACT((A.message),'/Message/OrchestrationName/text()').getstringval() Orch_name,A.Message,rowid from A2C_BTS_MESSAGETRACING A
12/02/2008 14:31:10 TOracleQuery $0310F6E0 End (100 records processed)
Duration = 1.078
12/02/2008 14:31:10 TOracleQuery SQLForm.TestQuery Start Query.Describe
SQL = SELECT * FROM A2C_BTS_MESSAGETRACING
12/02/2008 14:31:10 TOracleQuery SQLForm.TestQuery End
Duration = 0.016
12/02/2008 14:31:10 TOracleQuery Query Start Query.Execute
SQL = declare
doa_object sys.xmltype;
xmldata clob;
doa_object := :doa_object;
xmldata := doa_object.getclobval();
sys.dbms_lob.trim(:xmldata, 0);
sys.dbms_lob.append(:xmldata, xmldata);
:DOA_OBJECT = (Object)
:XMLDATA = (CLOB)
12/02/2008 14:31:10 TOracleQuery Query End
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Length
12/02/2008 14:31:10 TLOBLocator End
Duration = 0.016
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(31032)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(31123)
Duration = 0.016
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0.016
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(31157)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0.015
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(30823)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(31292)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0.015
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(31383)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(31417)
Duration = 0.015
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(31083)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0.016
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(17040)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(17131)
Duration = 0.016
12/02/2008 14:31:10 SQLForm Executing... (10)
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(17165)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(16914)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(17298)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(17389)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(17423)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(47748)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(47839)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(47873)
Duration = 0
SQL = declare
xmldata clob;
:XMLDATA = (CLOB)
Duration = 0
Duration = 0
12/02/2008 14:31:10 TLOBLocator Start LOB.Read(47482)
Duration = 0
12/02/2008 14:31:10 SQLForm Executing... (20)
:ID = Null
Duration = 0
12/02/2008 14:31:10 TSQLThread SQLThread Postmessage
12/02/2008 14:31:10 TSQLForm.ThreadFinished
12/02/2008 14:31:10 TSQLThread SQLThread Suspend
12/02/2008 14:31:11 TSQLForm.ThreadFinished: SQLThread.Suspended
12/02/2008 14:31:11 SQLForm 20 rows selected in 1.578 seconds (more...)
12/02/2008 14:31:11 NavigationBookmarks.EnableButtons(Rebuild)
12/02/2008 14:31:11 NavigationBookmarks: Backward=0, Forward=0
12/02/2008 14:31:11 TOracleQuery $0310F580 Start Query.Execute
SQL = begin
:LINE = Null
:STATUS = Null
12/02/2008 14:31:11 TOracleQuery $0310F580 End
Duration = 0
12/02/2008 14:31:13 TOracleQuery $0310F580 Start Query.Execute
12/02/2008 14:31:13 TOracleQuery $0310F580 End (1 record processed)
Duration = 0
12/02/2008 14:31:13 TOracleQuery PLSQLDevForm.ResolveSymbolQuery Start Query.Execute
SQL = declare
t_owner varchar2(30);
t_name varchar2(30);
procedure check_mview is
dummy integer;
if :object_type = 'TABLE' then
select /*+rule*/ 1 into dummy
from sys.all_objects
where owner = :object_owner
and object_name = :object_name
and object_type = 'MATERIALIZED VIEW'
and rownum = 1;
:object_type := 'MATERIALIZED VIEW';
end if;
exception
when others then null;
:sub_object := null;
if :deep != 0 then
if :part2 is null then
select /*+rule*/ constraint_type, owner, constraint_name
from sys.all_constraints c
where c.constraint_name = :part1 and c.owner = :cur_schema
and rownum = 1;
else
select /*+rule*/ constraint_type, owner, constraint_name, :part3
where c.constraint_name = :part2 and c.owner = :part1
and rownum = 1;
end if;
if :object_type = 'P' then :object_type := 'PRIMARY KEY'; end if;
if :object_type = 'U' then :object_type := 'UNIQUE KEY'; end if;
if :object_type = 'R' then :object_type := 'FOREIGN KEY'; end if;
if :object_type = 'C' then :object_type := 'CHECK CONSTRAINT'; end if;
return;
exception
when no_data_found then null;
end if;
:sub_object := :part2;
if (:part2 is null) or (:part1 != :cur_schema) then
select /*+rule*/ object_type, :cur_schema, :part1
where owner = :cur_schema
and object_name = :part1
and object_type in ('MATERIALIZED VIEW', 'TABLE', 'VIEW', 'SEQUENCE', 'PROCEDURE', 'FUNCTION', 'PACKAGE', 'TYPE', 'TRIGGER', 'SYNONYM')
and rownum = 1;
if :object_type = 'SYNONYM' then
select /*+rule*/ s.table_owner, s.table_name
into t_owner, t_name
from all_synonyms s
where s.synonym_name = :part1
and s.owner = :cur_schema
and rownum = 1;
select /*+rule*/ o.object_type, o.owner, o.object_name
from sys.all_objects o
where o.owner = t_owner
and o.object_name = t_name
and rownum = 1;
end if;
if :part3 is not null then
:sub_object := :sub_object || '.' || :part3;
end if;
check_mview;
return;
exception
end if;
from all_synonyms s
and s.owner = 'PUBLIC'
and rownum = 1;
and rownum = 1;
check_mview;
return;
exception
:sub_object := :part3;
where o.owner = :part1
and o.object_name = :part2
and rownum = 1;
check_mview;
return;
exception
if :part2 is null and :part3 is null
then
select /*+rule*/ 'USER', null, :part1
from sys.all_users u
where u.username = :part1
and rownum = 1;
return;
end if;
exception
if :part2 is null and :part3 is null and :deep != 0
then
select /*+rule*/ 'ROLE', null, :part1
from sys.session_roles r
where r.role = :part1
and rownum = 1;
return;
end if;
exception
:object_owner := null;
:object_type := null;
:object_name := null;
:PART1 = A2C_BTS_MESSAGETRACING
:OBJECT_TYPE = Null
:OBJECT_OWNER = Null
:OBJECT_NAME = Null
:PART2 =
:SUB_OBJECT = Null
:PART3 =
:DEEP = 0
:CUR_SCHEMA = A2C
12/02/2008 14:31:13 TOracleQuery PLSQLDevForm.ResolveSymbolQuery End
Duration = 0.015
12/02/2008 14:31:13 TOracleQuery PLSQLDevForm.ColumnQuery Start Query.Execute
SQL = select /*+rule*/ col.*, com.Comments
from sys.all_tab_columns col,
sys.all_col_comments com
where col.owner = 'A2C'
and col.table_name = 'A2C_BTS_MESSAGETRACING'
and com.Owner (+) = 'A2C'
and com.Table_Name (+) = 'A2C_BTS_MESSAGETRACING'
and com.Column_Name (+) = col.Column_Name
order by col.column_id
:TABLE_NAME = A2C_BTS_MESSAGETRACING
:OWNER = A2C
12/02/2008 14:31:13 TOracleQuery PLSQLDevForm.ColumnQuery End (1 record processed)
Duration = 0
12/02/2008 14:31:13 TOracleQuery PLSQLDevForm.ColumnQuery Start Query.Next for up to 1 record
Duration = 0
Duration = 0
Duration = 0
Duration = 0
12/02/2008 14:31:13 TOracleQuery PLSQLDevForm.ColumnQuery End (0 records processed)
Duration = 0
12/02/2008 14:31:13 SQLForm message, sys.xmltype, optional
12/02/2008 14:31:13 ShowColumnEditor a2c_bts_messagetracing.message
12/02/2008 14:31:13 LargeDataEditor: CreateParser
12/02/2008 14:31:13 LargeDataEditor: GetExportDir
12/02/2008 14:31:13 LargeDataEditor: SetXMLEditorSizes
12/02/2008 14:31:13 LargeDataEditor: LoadPosition
12/02/2008 14:31:13 LargeDataEditor: LoadXMLSplitters
12/02/2008 14:31:13 LargeDataEditor: SetupMainFont
12/02/2008 14:31:13 LargeDataEditor: Set HTML CharSet
12/02/2008 14:31:13 LargeDataEditor: ImageControl
12/02/2008 14:31:13 LargeDataEditor: Initialize XML Editor
12/02/2008 14:31:13 LargeDataEditor: Get MSXMLDOM
12/02/2008 14:31:13 DataEditor XML: "Msxml2.DOMDocument"
12/02/2008 14:31:13 ShowColumnEditor LoadFromStream
12/02/2008 14:31:13 ShowColumnEditor SelectSheets
12/02/2008 14:31:13 ShowColumnEditor DataToForm
12/02/2008 14:31:13 ShowColumnEditor ShowModal
Thanks for the reply,
I tried it but it did not help.
This used to work in previous release.
We had to upgrade due to using Oracle client 10.2.0.2
I see that the CLOB is only 47482 bytes long, so that can't be the problem. Does this only happen with CLOB's, or also with BLOB's and VARCHAR2's?
We don't use BLOB.
Varchar2 works fine.
Also, some CLOBs work fine as well.
I looked inside the CLOB. its an XML file and it works fine on the previous release.
I did not see any special characters init as well.
Would sending you the CLOB help you?
If so, please supply an email address.
Thanks for the help
Alon Peled
Okay, maybe there is something with the XML contents. Can you send me the exact XML contents as an e-mail attachment?
Hi Marco,
I have emailed a DMP file with a single table contaiing one row.
Please tell me if you can reproducde the bug.
Alon Peled
