shannonwrege
I just recently upgraded from version 3.3 to 3.4 of DOA, and all of my ClientDataSets no longer work properly. I think this is because of the enhancement in 3.4 that copies Params values into the variables ...
Delphi/C++Builder 5 Provider Support improvements
I have always been accustomed to defining the variables in the OracleDataSet, setting the variable values using SetVariables, and then opening the ClientDataSet. My ClientDataSet had no params. Now my problem is that the variables get cleared out when I open the ClientDataSet. I have this kind of code everywhere.
Is there a way to disable the copy?
Can the product be enhanced for backwards compatability (e.g. if the Params are empty, do not clear out the Variables)?
Thanks for any help.
Shannon
- Params from TClientDataSet are now copied to TOracleDataSet
- Fixed 'UpdatingTable required' error message for cursor datasets
Shannon
