Hello
I have found a little issue.
Suppose I have next code :
When I click the first and second lines I get the expected result. Cursor jumps to "procedure SampleTest" line in the same window.
But when I click to "TEST_SCHEMA.SAMPLE.SampleTest;" PLD opens new window and cursor jumps there. It is annoying...
Could You fix it?
SQL:
create or replace package body TEST_SCHEMA.SAMPLE is
is
SampleTest;
SAMPLE.SampleTest;
end SAMPLE;
Could You fix it?
