Character Set Problem
Oguz
I read the other topics about this problem but my problem is still going.
1) Ii changed the NLS_LANG parameter to HUNGARIAN_HUNGARY.EE8MSWIN1250 belong that path in regedit.
Bilgisayar\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\ORACLE\KEY_OraClient12Home1_32bit
2) Then i added belong sentence to params.ini
# plsqldev.exe nls_lang=HUNGARIAN_HUNGARY.EE8MSWIN1250
3) Then i runned belong code at the command window in plsql
4) But when i look the Help / Support Info at the plsql developer application i am seeing belong sentence block. So why this values are not changed by my regedit configuration idk.
Character Sets
Character size: 4 byte(s)
CharSetID: 873
NCharSetID: 2000
Unicode Support: True
NLS_LANG: TURKISH_TURKEY.WE8ISO8859P9
NLS_CHARACTERSET: AL32UTF8
Best Regards.
Can you run this command again?
Next, go to Help > Support Info and send me the text from the "Info" tab page.
Hello Marco,
I runned that command again and i sending the text.
Best Regards.
PL/SQL Developer
Version 14.0.6.1988 (32 bit)
01.261962
Service Contract: 31/12/9999
Windows 10 (64-bit) Build 19041
tr-TR(1055)/Türkçe (Türkiye)
Physical memory : 8,194,776 kB (1,081,560 available)
Paging file : 17,631,960 kB (4,586,228 available)
Virtual memory : 2,097,024 kB (1,620,740 available)
Parameters
C:\Program Files (x86)\PLSQL Developer 14\plsqldev.exe
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
C:\Users\IFS-OGUZHANK\AppData\Roaming\PLSQL Developer 14\Preferences\default\Default.ini
C:\Users\IFS-OGUZHANK\AppData\Roaming\PLSQL Developer 14\Preferences\IFS-OGUZHANK\default.ini
License File
C:\ProgramData\PLSQL Developer\aalf.dat
Debug file
C:\Users\IFS-OGUZHANK\AppData\Roaming\PLSQL Developer 14\PlSqlDev.elf
Plug-Ins
*Active Query Builder (C:\Program Files (x86)\PLSQL Developer 14\PlugIns\ActiveQueryBuilder.dll)
*PL/SQL Documentation (plsqldoc) (C:\Program Files (x86)\PLSQL Developer 14\PlugIns\plsqldoc.dll)
(* is Active)
Aliases
Homes
OraClient12Home1_32bit (C:\app\client\IFS-OGUZHANK\product\12.2.0\client_1)
DLLs
C:\app\client\IFS-OGUZHANK\product\12.2.0\client_1\bin\oci.dll
TNS File
C:\app\client\IFS-OGUZHANK\product\12.2.0\client_1\Network\Admin\tnsnames.ora
Using
Home: OraClient12Home1_32bit
DLL: C:\app\client\IFS-OGUZHANK\product\12.2.0\client_1\bin\oci.dll
OCI: version 12.1 (12.2.0.1.0)
Character Sets
CharSetID: 873
NCharSetID: 2000
Process
Working Set = 96,645,120
Memory = 63,870,540
GDI Objects = 1529
User Objects = 1137
Handles = 695
Monitor
PixelsPerInch = 120
Id = 0
PPI = 120
Primary = True
Handle = 65537
Left = 0
Top = 0
Width = 1920
Height = 1080
MainFormOnTaskbar = True
fd5Vg6T
The parameter list is as follows:
Parameters
This indicates that the nls_lang parameter is not coming through. Can you verify this?
