char and varchar2 columns
phoenix610
Hello.
It seems that the DOA treats both char and varchar2 data types as ftString type.
Why does not the DOA distinguish between char and varchar2 data types?
I think that in this case a problem will occur.
With updating records via the TDataSetProvider,
a string param of a SQLStatement generated automatically by a TSQLResolver alwayas is declared as DOA's otString type.
In this case, char columns is compared by a blank padding semantics, and so the end-user always have to input a char field value with padding blanks.Of course, it is possible for a filed value to be filled with blanks programtically.
the other driver as the Bolrand standard dbExpress driver distinguishes thease two data types and so the end-user can input a char field value without padding.
Is this the DOA specification?
Thanks.
Oh, I'm sorry.I made a mistake.
Line 9:
In this case, char columns is compared by a non-blank padding semantics
If you use char columns and trailing spaces are siginificant, you can set TOracleSession.Preferences.TrimStringFields to False.
Hi.
If I set TOracleSession.Preferences.TrimStringFields to False, I think that Padding with blanks is necessary.
For example, there is a table that has a char field named as FieldA and a char field named as FieldB.
At first, update only FieldA without padding blanks and apply changes to a DB by invoking a ClientDataSet.ApplyUpdates method.
To apply to a DB will succeed and a FieldA value on the server-side will be padded with blanks by Oracle.
Next, update only FieldB without padding blanks and apply changes to a DB.
To apply to a DB will fail(" a record has changed by another user" exception will be raised.) becuase FieldA value on the client-side differs from FieldA value on the server-side.
After all,whether TOracleSession.Preferences.TrimStringFields is Ture or not, I have to pad with blanks.
Thanks.
Oh.
Do you know Oracle non-blank and blank padding semantics in comparison?
It seems that you don't understand the differences
between no-blank padding sematics and blank padding semantics.
If you update a record by using TOracleDataSet, you don'nt have to pad with blanks because TOracleDataSet specifies a target record by Rowid.
But
if you update a record by using TClientDataSet,
you have to pad with blanks whether TOracleSession.Preferences.TrimStringFields is True or not.
'testvalue ' does'nt match 'testvalue' in a non-blank padding sematics.
I wonder why the DOA distinguish char data type from varchar2 data type and why can't you understand these differeces.
Please read Oracle Document.
If you tell that these behaviour is a DOA's specification, I accept these and tell you no more.
additional:
TSQLResolver automatically generates SQL statement like this.
update test_table set fielda = :newfielda
where fielda = :oldfielda and fieldb = :oldfieldb
If a FieldA is char data type,Ordinary you have to compare in blank padding semtaics.
the DOA always bind :oldfileda to a varchar2 data type and so either end-users or developers have to pad with blanks.It's complicated.
