PdS
Hello!
I now working on project where case-sensitive names of tables, fields and some triggers used "by-design" and migrated from previous version of application. I know - it's rare choice, but it's a big trouble for me that PL/SQL Developer wan't support this names correctly at all.
May be some settings i miss?
Any chance to support will be added at nearest time?
Any known workarounds about topic?
Unfortunately, for this time I found only one heuristic to enclose identifiers into double quotes, based on representation of object name in views such all_tables (all letters capitalized or not).
But, nevertheless, I hope, that this function will appear in the nearest versions.
Example code, based on my troubles
Such code autogenerated, and can't be changed
create table "MY_CaseTest" (
"KeyField" number(10),
"Field_Ref2" number(10),
field_val varchar2(1024)
create sequence "MY_CaseTest$T"
create or replace trigger "MY_CaseTest$$$StdTg"
before insert or update on "MY_CaseTest" for each row
if
new."KeyField" is null) then
select "MY_CaseTest$T".NextVal into :new."KeyField" from dual;
end if;
Developer wan't drop this objects, recompile, generate proper DDL, open trigger for editing and do some other things.
It's only trouble for me in PL/SQL Developer for now, all other things works perfect. Big thanks to developers of Developer!
if
end if;
