Edwin Godefrooij
If you create a table like:
-- Create table
create table TEST
"Id" NUMBER,
"Omschrijving" VARCHAR2(20)
and after that you use the assistent for filling in the columnnames (pulldown-list when you type t.), the following query is constructed:
select t.id from test t
After executed this you will receive the following error:
ORA-00904 - invalid column name
Because of the (maybe strange) way the table is created the query should be:
select t."Id" from test t
I ran into this problem after having done an import of table from MS Access.
-- Create table
create table TEST
"Id" NUMBER,
