Can't connect from VirtualBox virtual machine
freemink
I'm running Windows XP within VirtualBox on a Mac OS X host. On the Mac I connect to my company using vpn.
So, on the Windows (virtual machine) I can ping, and tnsping, and ssh, into the database server I'm trying to reach. I have Oracle client installed and pl/sql developer.
I followed the "Oracle Net Configuration Assistant -> Local Net Service Name configuration" as detailed here:http://www.allroundautomations.com/threads/ubbthreads.php?ubb=showflat&Number=30309#Post30309
I can connect using sqlplus with:
sqlplus user/password@//tahiti:1521/tahicr01
tnsnames.ora looks okay, windows hosts file is okay,
pl/sql developer has the oracle_home set correctly.
But when I try to connect PL/SQL Developer I get:
ORA-12154: TNS: Could not resolve the connect identifier
Any help appreciated,
Thanks, Darrell.
Okay, I sorted it out.
Started from scratch:
Running Windows XP in Virtualbox using NAT mode. Mac OS X host is running Checkpoint VPN secure-client.
In (virtual) Windows XP:
Installed Oracle Instant Client
Installed PL/SQL Developer (v7.1.5)
Checked windows hosts file.
Set environment variables ORACLE_HOME and TNS_ADMIN to directory where installed instant client to. I'm pretty sure that ORACLE_HOME wasn't used at all, but I did it anyway.
Create a basic sqlnet.ora in ORACLE_HOME
sqlnet.authentication_services = (ALL)
names.directory_lookup = (TNSNAMES,ONAMES)
names.default_domain = world
name.default_zone = world
Create tnsnames.ora in ORACLE_HOME
TAHICR01.world =
  (DESCRIPTION =
    (ADDRESS =
          (PROTOCOL = TCP)
          (HOST = tahiti)
          (PORT = 1521)
    (CONNECT_DATA = (SID = TAHICR01))
Started pl/sql developer which complained about a missing msvcr71.dll - I found the dll and copied to ORACLE_HOME
Restarted pl/sql developer and manually set 'Oracle Home' and 'OCI Library' from Tools->Preferences.
Restarted pl/sql developer and it worked!
