Hey there,
I'm currently evaluating the Trial Version to decide if we can use the product (if that matters).
I have the following problem:
When I edit a PL/SQL procedure (by choosing Edit in the menu) I can change the code within the window. However I cannot commit the changes to the database. The commit/rollback icons on the taskbar remain inactive.
Do you have any hints as to what I'm doing wrong? Do I have to start a transaction manually and how do I do this? It should not be an issue with the version being a Trial as it should be unrestricted, shouldn't it?
I can commit changes made to data within tables though.
Also is there a way when you navigate to an procedure contained in a package (via CTRL+click) that the body is opened instead of the declaration? Also it would be great if you can open the body or procedure automatically in Edit mode instead of View mode.
Thanks very much for your support and suggestions.
