can you help? How do I tell if a procedure parameter is optional?
Hi
I am an oracle problem which I am hoping you might be able to help with.
In my program at runtime, I get all the procedures in a package which the user can then run. Some of the procedures have parameters which the user enters, but some of these parameters are optional as they have a default value. e.g:
PROCEDURE kevins_test(p_foo in varchar := NULL);
What I want to do is let the user know that the parameter is optional. At first glance it would appear that there is a view for this: USER_ARGUMENTS which has a column called DEFAULT_VALUE, however this is 'reserved for future use'.
According to this post:
http://www.dbforums.com/archive/index.php/t-631096.html
I am going to have to use the ALL_SOURCE table and parse the source code. Sounds like fun.
Then I noticed that in PL/SQL Dev when you expand a package->procedure->parameters, the optional parameters have [] around them!
So my question is, how do your developers determine that a parameter is optional??
Many thanks
Kevin
It uses the Oracle Call Interface, which allows you determine if a parameter has a default value:
OCIAttrGet(ParamHandle,
           OCI_DTYPE_PARAM,
           HasDefault,
           Nil,
           OCI_ATTR_HAS_DEFAULT,
           ErrorHandle);
