I would like to run scripts withtin a Delphi program.
We usually run those scripts with sql*plus, but it lacks a proper command line support, in particular error handling and reporting.
So I plan to use TOracleScript instead of calling sql*plus from the command line, but I wonder if any of you have successfully used this component *and* if there are some limitations to it (i.e. any script executed with the component will produce the same output than sql*plus ?)
Kuzkot
Kuzkot
