CachedUpdates without ROWID
KAndrew
I copy this topic from the DOA Beta forum.
posted 12 September 2003 16:31
Hello Marco!
Are You planning release the CachedUpdates based on TOracleDataSet.UniqueFields? The ROWID is not suitable for any needs, e.g. updates Views with instead of triggers.
Andrew.
posted 18 September 2003 15:21
For views with instead of triggers you can still obtain a rowid. You must set the UniqueFields though.
posted 18 September 2003 18:27
Hi!
If view has DISTINCT, GROUP BY, UNION clause and join several tables all update logic release in instead of trigger, so ROWID cached updates works only with one updating table. I must specify UpdatingTable for CashedUpdates and DOA produce this statements:
DOA DMLQuery
1) select * from UpdatingTable where rowid = :doa__rowid
2) savepoint DOA_APPLYPOINT
3) select * from UpdatingTable where rowid = :doa__rowid for update nowait
4) update UpdatingTable set FieldName = :FieldName where rowid = :doa__rowid
5) commit;
If UpdatingTable is complex view then Oracle raise ORA-01446.
If UpdatingTable is one of the view's table,
I can update only one, instead of triggers not fired.
With unique fields
select * from UpdatingTable where UniqueFieldName1 = :UniqueFieldName1
[and
UniqueFieldName2 = :UniqueFieldName2
and so on..
This statements solve the problem.
This would be a great feature!
Regards,
Andrew.
Hello Marco!
I think, It's nessesary to introduce new property (UpdateKind ?) in the TOracleDataset, which determinate what kind of updates to use: ROWID or UniqueFields. There are no any difficulties to implement "UniqueFields" updates. I'm glad to help you.
Regards,
Andrew.
This is indeed not terribly difficult. We'll consider it.
