TOracleSession's ApplyUpdates() can be called, but apparently not linked. Here's how to reproduce the problem. Take the DOA DeptGrid demo, compile it, and run it. Everything's okay. Now add a line
if(0)MainSession->ApplyUpdates(0,0,false);
to any member function of TMainForm. You will be able to compile, but not link. The same problem occurs with CommitUpdates() and CancelUpdates().
Problem observed with C++ Builder 5 with the first patch, and DOA 3.4.3. I also have C++ builder 3, and will try it with that.
I suspect that it's a problem with the declaration of ApplyUpdates() in file Oracle.hpp. ApplyUpdates() does appear in the library file, but perhaps it has a different parameter list. The C++ compiler adds the parameter types to the function name (this is how function overloading is accomplished), so if the parameter lists don't match, this linker error is exactly what you'd expect.
Suggestions on how to fix it would be appreciated.
