sukhadukkham
please try the following:
no do a select on that table in the sql-window and try to step into the array-column. the result is empty. can you reproduce this?
regards
daniel
CREATE OR REPLACE TYPE ar_ts AS VARRAY(2147483647) OF TIMESTAMP(0) WITH TIME ZONE
CREATE TABLE TEST
ts ar_ts
TABLESPACE BASIC
INSERT INTO test ( ts ) VALUES ( ar_ts ( TO_TIMESTAMP_TZ ( '01.01.2007 01:00:00 +01:00', 'DD.MM.YYYY HH24:MI:SS TZH:TZM' )
, TO_TIMESTAMP_TZ ( '01.01.2007 02:00:00 +01:00', 'DD.MM.YYYY HH24:MI:SS TZH:TZM' )
, TO_TIMESTAMP_TZ ( '01.01.2007 03:00:00 +01:00', 'DD.MM.YYYY HH24:MI:SS TZH:TZM' )
COMMIT
regards
daniel
