Bug when setting DBMS scheduler job properties (By Month)
Stromgol
Edit or create a DBMS scheduler job.
In the By Month row, click the '...' button
Select January, February and March, press OK
The string generated will be 'Jan, , ' instead of 'Jan, Feb, Mar'
This bug has been reproduced on multiple machines.
This is a minor problem, everything works if you type in the string manually without using the selection dialog.
