dimensions
Hi there,
I think I have found a bug with the code parser. If I create the following package
CREATE OR REPLACE PACKAGE TESTPACKAGE AS
TYPE columnTable IS TABLE OF user_tab_cols%ROWTYPE INDEX BY BINARY_INTEGER;
TYPE tableRecord IS RECORD (details user_tables%ROWTYPE,cols columntable);
FUNCTION testmethod(
pDummy VARCHAR2
) RETURN tablerecord;
END TESTPACKAGE;
CREATE OR REPLACE PACKAGE BODY TESTPACKAGE AS
pDummy VARCHAR2
IS
lrecord tablerecord;
RETURN lrecord;
END testmethod;
END TESTPACKAGE;
then code completion fails on my system for the function testmethod. If you then remove the member data "cols" from the tablerecord record then code completion starts working again.
Hopefully this provides a simple and repeatable enough test case for you to improve the code parser to handle these situations.
Tom
pDummy VARCHAR2
END TESTPACKAGE;
pDummy VARCHAR2
IS
RETURN lrecord;
END testmethod;
END TESTPACKAGE;
Tom
