Bernhard S
I noticed the following bug. The first sql results in the error noted, obviously due to wrongly interpreting the semicolon as a sql terminator, despite it being enclosed in a block comment:
If you put the same block comment in one line, the error is avoided:
In a PSD command window both queries work fine.
select 1
from dual
where 1 in
; --=>ORA-01742: comment not terminated properly
(1);
select 1
from dual
where 1 in
/* ; */ --works fine
(1);
