BUG: Multi-Monitor Support?
timboc
I've noticed that many of the popups don't center properly when using multi-monitor support under WindowsXP. They end up showing the left half of the popup at the extreme right edge of my screen in which PLSQLDEV is running with the right half of the popup going off the screen (my second monitor is to the left of my main screen).
I've been fixing my own Delphi applications for this issue lately too (it's a setting of the default screen location).
-Tim
I've just started using a second monitor, and I am finding it a bit frustrating that the pop-up data entry box for run-time parameters always pops up in the centre of my primary monitor, een though I am running PL/SQL Developer full-screen on my second monitor. Perhaps the centre of the active Editor window would be a better bet???
