Bug: Invalid DDL for compressed primary keys
BWendling
I create my primary keys as follows:
1. Create a compressed (and local) index.
2. Create a primary key with the same name.
Oracle will then use the index created in step 1. This way, I can make full use of Oracle features (local, compress) which is not supported in the alter table statement.
Currently, generated DDL is:
alter table BRANCH
add constraint BRANCH_PK primary key (ASOFDATE, BRANCHCODE);
Instead, the DDL generator must generate compressed indexes (and in a later PLSD version local indexes) in two steps as outlined above.
Just in case what to do:
The correct DDL would be (you may omit the "local" keyword until PLSD supports it officially):
CREATE UNIQUE INDEX BRANCH_PK ON BRANCH (ASOFDATE, BRANCHCODE) LOCAL COMPRESS;
ALTER TABLE BRANCH ADD CONSTRAINT BRANCH_PK PRIMARY KEY (ASOFDATE, BRANCHCODE);
