Bug, Feature Request: Substitution variable does not work properly in Test window
Consider the code
declare
  dbms_output.put_line('&text');
In Command window and SQL Window it works fine, PSD ask for the &text value and substitutes is.
For Test Window it does not work - it asks nothing and just puts the &text into Output.
It will be nice to have True substitution behavior in Test window as well. Existing functionality implies that I need to use :text, but that is not true from SQL*Plus, ODAC and so on points of view (PSD's Command window as well), where & prefixed substitution variables are used instead of : ones.
Substitution variables working in ODAC? As far as I know, the substitution variables are a feature of the SQL*PLus application itself and for compatibility and comfort of use emulated (and enhanced) in other applications like PL/SQL Developer.
They are not a feature of Oracle Client or Oracle DB.
As the Test Window actually is for testing and debugging PL/SQL on Oracle DB, introducing substitution variables may introduce complexity (and thus user and application errors) without bringing much value.
