null0000
1.Open command window. [indicator to connection set to the Main connection]
2. try to connect to other instance [connection method is using drop-down list from connection indicator on status bar: Recent>{List of connections} ]
3. operation failed as the instance in shutdown state -
Ora - 01033.
4. Release Logon Screen by using Cancel. [Using OK goes in the loop, which perhaps also needs to be addressed]
5. connection indicator down on status line is CHANGED to unsuccessful connnection ??
Can you please fix it?
PLD - 10.0.1.1694
win7
Ora 10g EE, full client.
the same problem in 9.0.6.1665
Ora - 01033.
PLD - 10.0.1.1694
win7
