Another record-and-code-assistant related weirdism:
If a record type is defined in a package then code completion for variables of that type only works if the variable is declared as "type", and not if it is declared as "package.type".
CREATE OR REPLACE PACKAGE BODY pkg AS
TYPE rec_type IS RECORD (
a NUMBER,
b NUMBER);
PROCEDURE proc IS
var_1 rec_type;
var_2 pkg.rec_type;
var_1. -- use code completion here, works OK
var_2. -- use code completion here, does not work
END;
END pkg;
