I have dragged and dropped Navigation Forward/Backward icons (from Command Menu Edit Section) to the ribbon area. It seems sometimes they appear to be showing upto behave as Bookmark next/previous buttons instead. It seems the icons are the same for both types, so its even confusing as only hovering the mouse over them to figure out which one is used.
Or It could be that i may have accidentally used Bookmark button for some databases. Are the ribbon layout saved per database or per laptop logged in user or extended Win10 monitors please? I always login to laptop as the same user, however i do use different types of extended monitors all the time.
Sak
Version 12.0.2.1818 (32 bit)
Sak
