The beautifier is great most of the time, but there are things it can't handle. For example, it sucks when generating large XML files directly from query.
That is where I found that I could use the "--NoFormat Start" and "--NoFormat End" keywords to have a part of the SELECT ignored. But in 15.0.4 I have found a problem with it.
To recreate. Open a Test window.
Enter below:
First time I hit beautifier I get this:
It might be hard to notice, but I got an extra indention on the "--NoFormat Start" line.
If I rerun the beautifier this happens:
Suddenly everything gets indented, including the string, which really messes up my data output.
Please fix as soon as possible.
Best regards,
jaw
Enter below:
WITH a AS
(SELECT 123
FROM DUAL)
--NoFormat Start
SELECT XMLElement("DATA", XMLCDATA('Hi,
This is some long data that shouldn''t be touched since it is enclosed as string.
Best Regards'))
FROM a
--NoFormat End
WITH a AS
(SELECT 123
FROM DUAL)
--NoFormat Start
Best Regards'))
FROM a
--NoFormat End
WITH a AS
(SELECT 123
FROM DUAL)
--NoFormat Start
Best Regards'))
FROM a
--NoFormat End
Best regards,
jaw
