Beta 5: File Dialog Connection issue
Stew Stryker
My package spec and body are in separate files (.pks and .pkb, respectively) though I often open them together.
I just opened the pair of them and I specified a database connection. But only the first file got that connection, the other got the default/Main connection.
That is..
  • I have the Connection Session Mode set to Multi-session
  • I chose Open Program File
  • I selected 2 files to open (.pkb and .pks)
  • I changed the Connection from the Main to another from the Recents list
  • Both files opened,
    • the .pkb with my selected connection,
    • the .pks with the Main connection
Best of luck!
