I have a column in the database that is an XMLType. When I select from the table the XML doesn't appear, instead it just shows the column type, "".
I clicked the "..." hoping it would show me the XML, but instead it says:
What is the best way to use PL/SQL Developer with XML in the database? Is there an app to install? What is it called? How would I install it? Where is the "Default Apps Settings" page? Is there a way to get it to open Notepad++ to show me the XML, or is there something better?
This file does not have an app associated with it for performing this action. Please install an app or, of one is already installed, create an association in the Default Apps Settings page.
