Philippe Malera
Actually the beautifier return this :
But this look a bit strange, it should return this :
SQL:
SELECT x.*
FROM tmp_xmltype t,
xmltable(xmlnamespaces(DEFAULT 'urn:iso:std:iso:20022:tech:xsd:camt.054.001.04'),
'Document/BkToCstmrDbtCdtNtfctn/Ntfctn/Ntry' passing t.xml_data columns "REF" VARCHAR2(20) path
'NtryRef',
"AMOUNT" NUMBER(12, 2) path 'Amt',
"CURR" VARCHAR2(3) path 'Amt/@Ccy',
"VAL_DT" DATE path 'ValDt/Dt',
"DET_REF" VARCHAR2(30) path 'NtryDtls/TxDtls/Refs/EndToEndId',
"DET_NAME" VARCHAR2(30) path 'NtryDtls/TxDtls/RltdPties/Dbtr/Nm') x;
SQL:
SELECT x.*
FROM tmp_xmltype t,
XMLTABLE (XMLNAMESPACES (DEFAULT 'urn:iso:std:iso:20022:tech:xsd:camt.054.001.04'),
PASSING t.xml_data
COLUMNS
"REF" VARCHAR2(20) PATH 'NtryRef',
"AMOUNT" NUMBER(12, 2) PATH 'Amt',
"CURR" VARCHAR2(3) PATH 'Amt/@Ccy',
"VAL_DT" DATE PATH 'ValDt/Dt',
"DET_REF" VARCHAR2(30) PATH 'NtryDtls/TxDtls/Refs/EndToEndId',
"DET_NAME" VARCHAR2(30) PATH 'NtryDtls/TxDtls/RltdPties/Dbtr/Nm'
) x;
