It seems that the IS is getting an extra space when a comment is just before the IS. Also the second and the third comment lines do get two extra spaces.
This is the original code:
And this is what the beautifier does:
I can remove the extra spaces before 'Procedure description' and beautify it again without any changes. But removing the spaces before the last '---..' line it will add the spaces again when you beautify it.
PROCEDURE test
( p_id NUMBER
, p_name VARCHAR2
IS
NULL;
END;
PROCEDURE test
p_id NUMBER
,p_name VARCHAR2
IS
NULL;
END;
