Killservice
I don't know if this Problem is only pld 4b5 Problem or other Versions to.
if you beautifie this code
You don't have all ":=" equal justified.
I expect somthing like that
DECLARE
TYPE t_record IS RECORD(
var1 NUMBER(3)
,variable2 VARCHAR2(100)
,var_3 NUMBER(1)
,var_4_id VARCHAR2(5));
TYPE t_sa_33_tar IS TABLE OF t_record;
io_t_sa_33_tar t_sa_33_tar;
l_rec_ris t_record;
io_t_sa_33_tar(io_n_idx).var1 := l_rec_ris.var1;
io_t_sa_33_tar(io_n_idx).variable2 := l_rec_ris.variable2;
io_t_sa_33_tar(io_n_idx).var_3 := l_rec_ris.var_3;
io_t_sa_33_tar(io_n_idx).var_4_id := l_rec_ris.var_4_id;
END;
DECLARE
var1 NUMBER(3)
,var_3 NUMBER(1)
l_rec_ris t_record;
END;
