Beautifier: align alias does not work with DECODE or CASE
Scott Eli
The beautifier will align my column alias fine until I add a DECODE or CASE line to the SQL.
without DECODE
select subscriber_id as sub_id
      ,first_name    as sub_first
      ,last_name     as sub_last
  from subscrib
adding a DECODE
      ,DECODE(MI, 'A', 1, 0) as middle_initial
  from subscrib
Is this is expected behavior?
This is indeed a known restriction. Alignment will only work if you use plain column names. As soon as complex expressions are used, the alignment will no longer be applied.
