AV in module ORA804.dll after long working
I got following error from my server(using DOA):
Access violation at address 011E4306 in module 'ORA804.dll'. Read of address FFFFFFF8
Server is using DOA 4.0.5.0
Server was working from about 24 hrs.
I know that this error is cause due to some problem with ORA dll.
After restarting the server application, server works fine.
I want to know how can I reload the ORA dll if such exception occur without causing any problem to DOA working?
It may be difficult to clean up everything if Oracle Net is raising access violation exceptions. What you would have to do is:
1. Disconnect all session(s).
2. Call DLLExit (in the OracleCI unit).
3. Reconnect your session(s).
Note that it may also be a good idea to upgrade Oracle Net to 8.0.5 or later, because 8.0.4 was not the most stable Oracle Net version.
Is it not possible that I block all the call to Oracle (ofcourse from DOA) and call DLLExit (to unload the DLL) and then call DLLInit (to reload the DLL)?
If I have multiple TOracleSession then are they using same handle of ORA dll?
Can you tell me from where I can download the upgrade version of Oracle Net? I was unable to find it on net.
