Annoying problem
DoDo
Not version dependent ( ??? maybe from V6 ... ).
Whenever I try to retrieve an object from the big popup list (code assistance) that is at the bottom of the list, I have an annoying problem.
Try easily to retrieve an object that is at the bottom of the big list. If the list is in the SQL window that is not fully maximized, the bottom is not visible and it is difficult to navigate.
Also appears on all windows that have some sort of assistance list.
You will surely replay: Type in more letters and the list will be reduced!
But it is not always the solution of the problem.
Please do something.
We'll fix it. The Code Assistant should always remain completely visible within the window.
As a workaround you can resize the Code Assistant to reduce the chance that this will happen.
