ANN: Fast Script 1.2
Dear friends!
Good news from our team.
FastScript 1.2 released.
Changes:
- fixed 'eventhandler = nil' bug
- fixed sets bug
- fixed default and index properties bug
- fixed 'not' operator bug
+ added TfsScript.GetILCode and TfsScript.SetILCode methods. It allows
you to save precompiled code and restore it later.
* changed 'uses' behavior. Now FastScript returns more information
about error in used module. Each used module must
contain begin..end section like the
main module. Modules cannot contain duplicate variable/method names.
See more: http://www.fast-report.com/en/fastscript.php
+ Free upgrade to FastScript 1.2 for registered users of FastScript 1.0/1.1.
+ Special discounts for our customers (FastReport and FastExperts).
FastScript is cross-platform multi-language scripting engine. It is
intended for programmers who want to add scripting ability to their
projects. FastScript is written on 100% Object Pascal and can be
installed in Borland Delphi 4-7, Borland C++Builder 4-6 and Borland
Kylix 1-3.
One of the key features of FastScript is ability to use several
languages (PascalScript and C++Script), so you can write scripts
using your favourite language. PascalScript is subset of the Object
Pascal programming language, C++Script is subset of C++.
FastScript doesn't use Microsoft Scripting Host, so it can be used in
Windows and Linux environment. It is possible to add a new language -
language definition is stored in the XML format, so you can do it
without writing a Delphi code.
Features:
- Classes and functions tree-view.
- Syntax highlighting memo with bookmarks.
- Multi-language architecture allows you to use many languages (at
this moment - PascalScript and C++Script). It is
possible to add any procedural language (language definition is stored
in XML format).
- Standard language features: variables, constants, procedures,
functions (nested allowed) with var/const/default
parameters, all standard operators and statements (including case,
try/finally/except, with), types (int, float, bool, char, string,
multi-dimensional array, enum, variant), classes (with methods,
events, properties, index and default properties).
- Strict type checking.
- Access to any object inside your application. Standard libraries to
access to base classes, controls, forms and DB.
Easily expandable library architecture.
- Small footprint - 80-150Kb depending on modules used.
Best regards,
Ann Ivanova mailto:ann@fast-report.com
Fast Reports - cross-platform multi-language solutions for developers
http://www.fastexperts.com
Delphi Informant Magazine Readers Choice Awards 2003
Runner Up Best Reporting Tool
FastReport http://www.fast-report.com
All results can be found at
http://www.delphizine.com/opinion/2003/09/di200309jc_o/di200309jc_o.asp
