Ajnother parsing question
ltd
i have the following problem.
When i use a TOracleQuery to execute the following code i get parses on the database for every call.
"begin
Return:=Mypackage.Myfunc(:Par1,:Par2);
end;"
When i call the following code i get no extra parses:
"begin
MyPackage.Myprocedure(:Par1,:Par2,:Par3);
end;"
All variables are declared and are of standard types ( otString, otInteger). I am not closing the query. So my question is why is an PL/SQL function( or the return variable) forcing a reparse on every call?
I use DOA 3.4.5 on BCB5 with different Oracle versions. Test was done against Oracle 9.2.0.3.0.
Best regards,
Lars
The first call is not correct (Return is not declared) and should raise an exception. This would cause a reparse the next time, but I assume this is not what really happened?
Hi, there was one ":" missing in the example.
Here is the real code:
pqPeerState->SQL->Add( "BEGIN" );
pqPeerState->SQL->Add( ":nRet := "+asPackageName+"PEERSTATE( :nIDInstance, :nIDOperator, :tBitPos,"
" :tBitValue, :nSize, :vcEtc, "
" :nIDErrorText, :vcErrorText, :iDoCommit ); "
pqPeerState->SQL->Add( "END;" );
pqPeerState->DeclareVariable( "nRet", otInteger );
pqPeerState->DeclareVariable( "nIDInstance", otInteger );
pqPeerState->DeclareVariable( "nIDOperator", otInteger );
pqPeerState->DeclareVariable( "tBitPos", otInteger );
pqPeerState->DeclareVariable( "tBitValue", otInteger );
pqPeerState->DeclareVariable( "nSize", otInteger );
pqPeerState->DeclareVariable( "vcEtc", otString );
pqPeerState->DeclareVariable( "nIDErrorText", otInteger );
pqPeerState->DeclareVariable( "vcErrorText", otString );
pqPeerState->DeclareVariable( "iDoCommit", otInteger );
After that there are only calls to set or get variable values and calls to execute the procedure
Lars
[This message has been edited by ltd (edited 24 July 2003).]
If you declare variables before each execute call, the query will be reparsed. If the variable types don't change, do not redeclare them to prevent extra parse operations.
Hi Marco,
another missunderstanding due to my example not beeing clear enough.
The code in my previous mail is in the constructor. After that you only find something like this ( code comes from another query) :
pqDestReq->SetVariable( "nIDOperator", GlobalOperator.GetUserId());
pqDestReq->SetVariable( "tLocation", tData.Scanner.setLocVariant());
pqDestReq->SetVariable( "nPIC", tData.PIC);
pqDestReq->SetVariable( "vcBarcode", tData.Barcode);
pqDestReq->SetVariable( "vcEtc", tData.OtherData);
pqDestReq->SetVariable( "iDoCommit", 1);
pqDestReq->Execute();
if( pqDestReq->GetVariable( "nRet" ) < 0 )
uiIDErrText = pqDestReq->GetVariable( "nIDErrorText" );
asErrText = pqDestReq->GetVariable( "vcErrorText" );
There are no redeclarations and as i said when i use a procedure instead of a function i get no reparses. The only difference i can see is the ":nRet" Variable and as i said i never redeclare anything after creating the query in the constructor.
